Author Topic: Very tall SMD LEDs?  (Read 1646 times)
Offline jayeyeTopic starter
  • EE-turned-CS, security/networking/embedded-systems
Very tall SMD LEDs?
« on: February 10, 2019, 01:16:48 am »
I need to mount indicator LEDs 30mm above the PCB. I'm making fewer than ten pieces of this, so having light pipes manufactured is not an option. I *could* solder some wire to ordinary T-1 (3mm) LED to lengthen the pins, and even twist it so they become surface-mount, but that's way too ugly, and in any case the leads are not stiff enough to keep the LEDs properly positioned. I looked through LED accessories on Digikey, but I can't find anything suitable. Suggestions?
/ji
Offline djacobow
  • takin' it apart since the 70's
Re: Very tall SMD LEDs?
« Reply #1 on: February 10, 2019, 01:20:15 am »
I wonder if you could "manufacture" a few light pipes using some plexiglass and some careful sawing.
Offline sokoloff
« Reply #2 on: February 10, 2019, 01:26:21 am »
For fewer than 10, I'd probably just use a tiny daughter board with pin headers and Dupont F-F jumpers to join the main board.
The following users thanked this post: TomS_
Offline fossil
  • Country: in
« Reply #3 on: February 10, 2019, 01:26:51 am »
/ji
Checkout out Light Pipes at https://lcsc.com/products/LED-Light-Pipes_977.html
« Last Edit: February 10, 2019, 02:46:52 am by fossil »
Offline Kasper
« Reply #4 on: February 10, 2019, 02:23:22 am »
Search DK for 'light pipe'.
Offline georges80
« Reply #5 on: February 10, 2019, 02:53:19 am »
If you have a place that sells plastic around where you live (I do...) you can source some small diameter acrylic rod easily. Cut to length and then just sand the ends with some wet/dry fine paper. Instant light pipe. Simple.
cheers,
george.
« Reply #6 on: February 10, 2019, 02:54:04 am »
Success! https://www.digikey.com/product-detail/en/LPV2-1250DP/492-2426-ND/8595199 and https://www.digikey.com/product-detail/en/VLP2-D-6/RPC5350-ND/3819305
I have no clue why I didn't find them earlier; I think I was looking just in the LED section of the catalog. Now on to figure out what LED of the several thousand options to use :)
It still amazes me that a piece of molded plastic is so much more expensive than a microcontroller with a billion transistors, but that's supply and demand for you!)
Thanks!
/ji
Offline Kasper
« Reply #7 on: February 10, 2019, 04:35:42 am »
Now to choose from the plethora of LEDs and pipes.
Some light pipes have a bunch of similar models with different heights and angles that all fit the same footprint. I recommend one of those so its less of a pain when your mech dimensions change.
