Author Topic: 300kV Cigarette Lighter  (Read 6565 times)
Offline HackedFridgeMagnetTopic starter
« on: August 04, 2016, 01:47:34 am »
 :o
what can I say?
The following users thanked this post: MagicSmoker, vinicius.jlantunes
Offline whitevamp
Re: 300kV Cigarette Lighter
« Reply #1 on: August 04, 2016, 02:33:45 am »
well thats one way to light a cig/fag
Offline ZeTeX
  • Country: il
  • When in doubt, add more flux.
« Reply #2 on: August 04, 2016, 11:03:22 am »
"Got a lighter?"
- "Sure"
"MOTHER OF ALL LIGHTERS  :wtf:"
Offline timb
    • timb.us
« Reply #3 on: August 04, 2016, 11:17:30 am »
Huh... So that's what they mean when they say "Smoking Can Kill You"!
Offline ZeTeX
  • Country: il
« Reply #4 on: August 04, 2016, 11:18:22 am »
Fry You*
Offline timb
    • timb.us
« Reply #5 on: August 04, 2016, 11:25:31 am »
Fry You*
And I thought that only could only happen if you fell asleep in bed with a lit cigarette. (Which apparently is, or at least used to be, a fairly common occurrence, to the point they had to create ads warning people not to smoke in bed! It also helped spur the advancement of mattresses and bedding that simply melted instead of bursting into flames. The more you know! ~~~~#)
Offline ZeTeX
  • Country: il
« Reply #6 on: August 04, 2016, 11:33:08 am »
Fry You*
what
How can someone fall asleep with a cigarette in his hand?
why even take the risk? and the ashes on the bed..
asking to burn yourself pretty much..
Offline timb
    • timb.us
« Reply #7 on: August 04, 2016, 12:01:24 pm »
Fry You*
what
If you think that's dangerous, imagine the guys using 200-300W eCig mods. They're basically shorting an 18650 cell across a 0.15ohm piece of steel or nickel wire, inches from their face! *Shudders*
Sent from my Smartphone
Offline Gyro
« Reply #8 on: August 04, 2016, 12:50:15 pm »
what
It's just a Darwinistic extension of 'How can someone smoke in the first place?'  :(
Best Regards, Chris
The following users thanked this post: Kilrah
Offline TerraHertz
    • It's not really a Blog
« Reply #9 on: August 04, 2016, 01:07:14 pm »
Pretty sure that is trick photography. Perhaps they are standing some distance behind the arcing insulator?
Much like the famous "Tesla seating reading book among lightning arcs' picture was something he did with double exposure.
« Reply #10 on: August 04, 2016, 02:21:13 pm »
Wouldn't be so sure, I think they moved in close once the arc struck.
Nice photo though.
I think one of those guys must have fathered PhotonicInduction.
« Last Edit: August 04, 2016, 02:23:29 pm by HackedFridgeMagnet »
Online Buriedcode
« Reply #11 on: August 04, 2016, 02:26:42 pm »
I wonder if any tesla zealots will jump on that.... maybe 'the system' has got to you too!!
Offline Richard Crowley
  • KJ7YLK
« Reply #12 on: August 04, 2016, 04:23:52 pm »
There are now spark-gap lighters widely available. Colorfully referred to as "Tesla coil" or "plasma" and rechargeable via USB.
Here is a YouTube video of someone who hacked one into a mini "plasma cutter" for paper, etc...
https://youtu.be/uKmGVNs_y7o
Offline Frank_22
« Reply #13 on: August 10, 2016, 07:36:25 am »
 |O smoking was never so complicated...
Online amyk
« Reply #14 on: August 10, 2016, 10:36:18 am »
bigclivedotcom has a video on these too:
Online Buriedcode
« Reply #15 on: August 10, 2016, 11:56:31 am »
I wouldn't have thought that frequency is nearly high enough for the sort of 'tricks' you see with tesla coils (the skin effect), no wonder he got a shock...  Also, its unlikely to be a neat sine wave as its a blocking oscillator flyback, so the output voltage can be much higher than simply down to the turns ratio (current source output).
I had an old 'electronic' cigarette lighter, I think it was from the 60's or 70's, powered by a small 12V battery (not piezo!) that generated a 1hz arc for igniting the gas - hardly the same as that beast but I was impressed by the ingenuity as it must have been 4-5kv albeit tiny current (pretty much felt like a piezo zap).
