hi, I have a problem where at voltage lower then 7V the regulator always must have 7V on the input, even if the output voltage is 10mV it still needs over 7V on the input, if the output voltage is higher then 7V then the dropout voltage is fine. (1-1.5V).
here is the schematic + download for ltspice *.asc:
