Author Topic: Game show buzzer using a micro controller  (Read 1987 times)
Offline 4013DlatchTopic starter
« on: May 23, 2015, 02:08:37 am »
Hi
I'm looking to convert my game show indicator lockout circuit from the original design using 14000 / 4000 series logic to a micro-controller based design, but I do not have a clue what to look for.
Here are the system specs:
  • 15 contestant switches N.O.
  • 15 corresponding LEDs and aux output in parallel
  • 1 LED that comes on if any of the above LEDs is lit
  • a reset switch to blank the LEDs and reset the latches
  • a buzzer that beeps 0.5s to 1s when a contestant light is triggered or the timer reaches 0
  • a timer package that has 5 different push button inputs
  • a 5s or 30s on one switch that is selected automatically based on whether or not a contestant has triggered the system
  • a 45s switch
  • a 60s switch
  • a timer pause / hold switch
  • a timer reset switch
  • a 2 digit 7-seg display
  • the timer uses a divided 60Hz signal input coming off of the mains transformer
System requirements:
  • Inputs debounced
  • timer display can be driven separately
  • LEDs can be driven separately
  • current systems operate on 8 Volts regulated, with 12 volt AC input clock signal. ( the ability to operate at this voltage is preferable
If I could get info as to what I'm looking for in a micro, in relation to I/O, peripherals, and anything else to consider as I'm totally new to micros.
Also I'm not set on a particular companies micros, so I'm game for almost anything as long as the tools are easy to use.
Mike
« Last Edit: May 23, 2015, 02:19:54 am by 4013Dlatch »
Offline Richard Crowley
  • KJ7YLK
Re: Game show buzzer using a micro controller
« Reply #1 on: May 23, 2015, 02:59:23 am »
Probably the most popular microcontroller platform out there now is Arduino.
There are a great many people making Arduino clones, some of them <$5
Everything you describe is pretty easy to do with Arduino, even with off-the-shelf I/O expander boards, etc.
There are many resources available online including example circuits and code, tutorials, and peer-assistance on the Arduino forum.
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #2 on: May 23, 2015, 05:36:43 am »
I'm interested in what you're doing - I've done a few game control systems ... including a licensed version of Wheel of Fortune... and others for on camera TV production.
Not sure where you are located, but if I can be of help, drop a line.
You can take these systems as far as you can imagine...
I've had networked systems with touch-screens, midi integration (for audio cues), power & DMX (lighting effects), multiple displays, projectors etc...
One element that shouldn't be overlooked or underestimated is a (secure) 'pre-game' editor to setup playing conditions etc. -- if your application goes that far.
Cheers
Don't ask a question if you aren't willing to listen to the answer.
« Reply #3 on: May 23, 2015, 12:53:17 pm »
Cheers
the pre game setup is done with switches.
I'm located in Manitoba Canada
Offline SL4P
« Reply #4 on: May 23, 2015, 09:32:20 pm »
I guess we're a bit far apart to meet up, but drop a line if up you get stuck... maybe I can help!
