So - while doing this project, I chanced upon some old early 1970's diagram of non-OTA using, modified Sallen/Key filter designs. They did mention you have to be "imaginative" to acheive it, but if you aren't that concerned about linearity (which I'm not) and more concerned with that ephemeral "sound" - of the resonance especially, reverse biased NPN's do the trick. Essentially, they are configured as current-controlled resistors.
I'm still iterating on this design (hence the horrible OA input and output hi-pass sections), but it sure does acheive what was needed - voltage control of cutoff. And without a large degree of distortion.
To add even more nonlinearity, one could throw antiparallel diodes in the feedback path. All in all, an interesting topology which is straight outta normal Sallen/Key territory (see the attached diagram).
I'll get around to implementing it in a non-bredboard form probably today. Might post some audio examples. Also, I'm thinking of controlling the feedback resistance with a photoresistor, since that bit doesn't seem as amenable to voltage control. But, VC of resonance is a lesser concern :-)
