So I'm building a small project. It will be either a "pre-cooling" mist system or a direct evaporation system for my home AC unit. The potential savings are well worth the effort. And it's a project we could all use here!
My goal is to keep it around or under $100.
Back story: So I was cleaning my outside coil (summer here in the US), and noticed that while wet, it cooled much more quickly and to a much lower temperature. So I looked around and found some people use "misters" for cooling. However, these are ridiculously priced and gimmicky.
Would "pre-cooling" with a misting system be better/more efficient than spraying larger droplets directly on the coil radiator fins (basically a heatsink)? It seems like having the water directly on the fins would make it more efficient to me. However, everything I see available for purchase is a pre-cooling system.
So, because of the expense of such systems, I've decided to build my own. XD I wasn't able to find previous projects, so give me a link if you find one! I've put the problems in a few categories:
1. I will need some sort of
control system (active, or passive) because I want it automatic. To save water, and to make the system less of a hassle. I have some spare raspberry pi's that I could use for this project. It might be worth getting an arduino, though. That might help for I/O reasons and power consumption. An arduino might be able to run with a small solar panel. What would be better? I've seen passive valves with air paddles that activate when the coil fan is on. This should work well enough, but I want to consider other options to see if I would get any advantages from a controller or something else.
2.
Water source and pipe/hose system. ... I live in California. Keeping water use (and energy use) down is important, and I may need to adapt the system to use a reservoir of some sort so that I could just filter and re-use waste water instead of tap water. If I do a reservoir system, I would need a pump system as well. I'm hoping to get by with just tap water, though. Either way, I need a way to get some sort of water to the unit, in an unobtrusive way. Keeping a garden hose hooked up to it would probably not be an option.
3. Some sort of water-emiting device like a
mister or sprayer. I don't know which type would be better. However, I have seen pre-made setups with small hoses and nozzles that I can probably adapt well... and go for
pretty cheap. Unfortunately, I see no flow data on devices I've seen so far.
Adjustability would be nice. I suppose I might be able to add a control valve, BUT that might reduce sprayer efficiency above/below design flow rate... but without data, I can only guess/test :/
I am also considering a "trickle" system of some sort, to trickle water from the top of the coil down, instead of spraying or misting. At the moment, I'm not sure what the advantages or disadvantages would be. I would guess that spraying or misting systems would be more efficient, given the greater surface area. But... if it was adjusted so that it all evaporated, and there was no runoff, would it be just as efficient then?
4. Water
filtration. This will hopefully be simple to implement, with
ready-made filters that take out calcium carbonate and minerals.
5.
Powering the device(s). I either need a solar panel, battery system, or an unobtrusive way to power it from tapping into the A/C unit lines. There is a 25v AC line, but I don't think there are any DC lines. There is a window right by the unit, so I might be able to run a flat power cable under the window and out to the unit. the power requirements will hopefully be either none (all passive) or minimal (just the arduino), but may be more.
So what do you think? At the moment, I'm trying to decide between the above options to see which ones to go with so I can start building and designing. I would greatly appreciate some input!
