Author Topic: What should the vacuum pressure of a desoldering gun be  (Read 931 times)
Online Alex EisenhutTopic starter
  • Place text here.
« on: August 04, 2020, 12:43:44 am »
They really do call it a vacuum pressure. My old Hakko 707 is spec'd at 600mmHg of vacuum pressure, which means 23 inches of mercury below atmospheric of 30 inches, I guess. The newest Hakkos are rated the same. My 707 has a pump with a home-made diaphragm in there since the original part disintegrated.
http://www.hakko.com/english/products/hakko_fm204_set.html#productNav
The 707 does work, but since I finally received my eBay vacuum gauge, I jammed the tip of the iron right into the port hole of the thing and pulled the trigger. I measure about 18 inches.
Is the vacuum pressure rated right at the the pump or at the tip of the iron? And how much vacuum am I possibly losing in the tubing and the joints in general?
It's nothing major, just curious.
Offline Circlotron
Re: What should the vacuum pressure of a desoldering gun be
« Reply #1 on: August 04, 2020, 01:00:14 am »
If the flow has stopped and there are no leaks there will be no loss of vacuum regardless of any restrictions.
