Hi Guys,
I'm new and happy to be here!
I'm starting a little circuit based on a voltage regulator, to convert 12V to 11V. This LM2941SX regulator has an ON/OFF pin that I want to use to delay the 11V power on (for example, when 12V is present at the input, the 11V output will be ON after around 500ms).
The ON/OFF pin enables the regulator at low state (under 2V).
My idea was to add a RC model to controls the ON/OFF pin, so when the 12V appears, the RC output will be 12V, then slowly decreasing until reaching 0V.
Do you think it's a good idea? Seems too easy for me
Have a nice day!
Halban
