Author Topic: YOYcart experience  (Read 10760 times)
Offline digsysTopic starter
    • DIGSYS
YOYcart experience
« on: October 17, 2018, 12:50:27 pm »
Anyone have any actual experience with YOYcart.com ? Are they a possible complete scam?
I've been searching for an old machine LCD, and after days only ever found 1 possible from reliable sites. Yet, I find 100s from 4-6 suppliers on
YOYO ??? None of them reply to questions though and their checkout is waay sus. Just looking for actual experience before I do a test run.
    • DIGSYS
Re: YOYcart experience
« Reply #1 on: October 29, 2018, 09:58:56 pm »
No takers? Just looking for anyone with any dealings at all. I did a couple test runs, and cancelled after suspect requests -
I can't see how they could be a 100% scam with many 100s+ listings (possibly 1000s). An unregulated ebay clone?
Offline thm_w
  • Non-expert
« Reply #2 on: October 29, 2018, 10:41:04 pm »
    • DIGSYS
« Reply #3 on: October 29, 2018, 10:52:27 pm »
Quote from: thm_w
... ca.trustpilot.com/review/www.yoycart.com ...
Tks. Saw all those. Just looking for any actual experience. Hard to believe it's a 100% scam for all those listings.
Offline thm_w
  • Non-expert
« Reply #4 on: October 29, 2018, 11:00:10 pm »
Can you post the LCD part number?
They seem to be scraping some listings from TaoBao. It could be some automated system that re-lists translated items, which would explain why a lot of the description/shiping costs/etc gets screwed up.
In terms of buying from taobao, if the seller has a number of purchases they are legit. A lot of zero purchases its hard to tell if seller is legit or they even have the item (I haven't had any experience with disputes/refunds so can't comment on that). Easiest to buy through an agent (ie basetao, etc.). The seller will ship to them and then re-ship to your country.
    • DIGSYS
« Reply #5 on: October 29, 2018, 11:12:29 pm »
Quote from: thm_w
Hitachi TM26D60VC1AA
There seems to be only 1 legit one on the whole planet, it's a very rare item, but yet YOYcart seem to have 100s ie
https://www.yoycart.com/Product/564015160936/
https://www.yoycart.com/Product/564167097397/
https://www.yoycart.com/Product/569368916240/
etc
If they were scraping other sites listings, I'd be able to find those? History? It seems odd that there are so many hits for a very rare item. Don't get it.
Offline thm_w
  • Non-expert
« Reply #6 on: October 29, 2018, 11:56:00 pm »
The first link is the same photo as this taobao listing: https://www.superbuy.com/en/page/buy?url=https%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fid%3D564015160936&nTag=Agent-product-taobao
Third link is this one: https://www.superbuy.com/en/page/buy?url=https%3A%2F%2Fitem.taobao.com%2Fitem.htm%3Fid%3D569368916240&nTag=Agent-product-taobao
So they are either an automated/manual taobao agent.
The first listing could be legitimate, but its almost certainly a pull from used equipment. Since I see a CCFL backlight, that likely is well used and could be dim. The third link may be a new part due to the high cost.
We purchased ~100pc displays from a chinese supplier, and the parts were used pulls (they don't specify new or used, so..). Some were water damaged, many were dim, so its not clear if they tested them at all or just pulled and cleaned them a bit.
Might be worth ordering a few from the first listing if you don't care about it being a used part. Maybe buy through a decent agent (or direct if possible), and let them know you have to test it before you know its good or not.
Compatible parts could exist as well.
    • DIGSYS
« Reply #7 on: October 30, 2018, 12:27:05 am »
Thanks a lot for that. All I can say is - Geezus, what a mess :-)    SO I found this though -
"Caution only people with a Chinese address and bank account can buy from taobao. There are also allot of fake items on there so caution must be used.
For foreigners to buy from taoabo you need to use a middle man that lives in China that can buy for u from taobao. I used http://taoabonow.com "
So I search for an Aussie agent I guess? Price doesn't concern me, and If I lose a couple, no biggie.
At least I have a possible start point .. thanks again
Offline snovotill
« Reply #8 on: September 19, 2019, 09:34:08 pm »
I've been using YoyCart for some time now and it's always been great. Their customer communications are good and it's the cheapest way for me to get small items delivered from TaoBao because they do ship to Canada via airmail whereas TaoBao direct only goes via the more expensive DHL, EMS, UPS and so on. Anything up to about 200 grams packaged weight is best via YoyCart but keep in mind that a small cardboard box can weigh 150 grams, so don't underestimate your shipping weight!
Also, their TaoBao views are automatically generated, so if there are Options Buttons on the TaoBao page then you need to specify these to YoyCart customer service via their chat. If you want heavy or bulky items then YoyCart is NOT going to be a good deal and you should go direct to TaoBao or to some other forwarding agent.
« Last Edit: September 19, 2019, 09:36:40 pm by snovotill »
Offline M4trix
  • Country: hr
« Reply #9 on: April 21, 2024, 10:41:08 pm »
*bump
what do you guys think about these listings ?
https://www.yoycart.com/Product/572545444014/
https://www.yoycart.com/Product/529107306192/
I'm looking for Toshiba's obsolete 2SA1924/2SC3425. I'm trying to contact the sellers but to no avail. Also, there are a lot of
sellers on Ali and eBay but their transistors have markings that do not comply with Toshiba's datasheet. For example:
Toshiba datasheet markings:
Alexpress :
These ones do not even have the Toshiba logo, for Pete's sake !
I have never seen Toshiba marking the transistor this way. Just look at it. It's like someone manually printed with silkscreen mesh. Btw, it's the right transistor case (TO-126F).
Dunno, probably fakes. Yes I know the basic rule: do not buy obsolete transistors on Ali and ebay. But those transistors on YOYcart looks genuine.  :-//
« Last Edit: April 21, 2024, 11:09:40 pm by M4trix »
Offline M4trix
  • Country: hr
« Reply #10 on: April 22, 2024, 01:48:17 am »
*bump
Meh, forget about it. Live chat is broken, contact seller is broken, live help is broken, broken English all over the place. Fake website is written all over it.  :palm:
Offline thm_w
  • Non-expert
« Reply #11 on: April 22, 2024, 10:58:28 pm »
Don't know: https://item.taobao.com/item.htm?abbucket=12&id=668570809767
Maybe legit: https://item.taobao.com/item.htm?abbucket=12&id=571378639095
Probably legit pulls if the image is accurate: https://item.taobao.com/item.htm?abbucket=12&id=601457612759
Bulk: https://octopart.com/2sa1924-toshiba-14313582?r=sp
I would find a modern alternative if you can instead of spending time finding the original.
Offline M4trix
  • Country: hr
« Reply #12 on: April 23, 2024, 12:03:54 am »
@thm_w, thank you for your effort. I gave up already. Sellers often show a picture of a genuine transistor but send fakes. It's too risky.
Edit:
Yes, those look genuine but that same picture is all over the net. 2SA1924/2SC3425 are simply way obsolete. I have to find substitutes.
« Last Edit: April 23, 2024, 12:10:16 am by M4trix »
Offline M4trix
  • Country: hr
« Reply #13 on: May 28, 2024, 05:42:38 pm »
*Bump
Ok some updates. I was testing my luck so I purchased 10 pieces of 2SA1924. I was expecting to receive this :
...but got this:
As you can see, fake is written all over them. Toshiba's original 2SA1924 are manufactured in a TO-126F case completely molded in plastic. The difference is obvious. That's about the transistor case.
Now some testing that I've done. Most of them fail around 50-60VDC ( one failed around 10V...lol ), but some do withstand 400VDC even more. Hfe is around 125.
So, all of them ended in the trash can. Fortunately I paid only $10 bucks with shipping. I wrote a letter to the seller but I doubt my words will have any effect on him.
Before I bought them I asked the seller, do they look like those on his picture. He replied, yes couple of times. Not only a dishonest seller but a liar as well. I know that
Alitard and eBay are not the places to search for obsolete parts. Especially if they're dirt cheap. I wasn't optimistic from the beginning so I'm not over-shocked.
I learned my lesson long time ago but you know that saying... curiosity killed the cat.  :D
« Last Edit: May 29, 2024, 07:08:08 pm by M4trix »
Offline M4trix
  • Country: hr
« Reply #14 on: May 29, 2024, 04:56:48 pm »
*Bump 2 - Update 2
Finally good news men ! Today I received Toshiba 2SC3425. Proper case, TO-126F and after some tests they met the specifications according to Toshiba's
datasheet. Now I have to find a reliable source of 2SA1924.  |O
Seller: https://www.yoycart.com/Product/572545444014/
Breakdown Voltage: 460VDC
hfe: around 40-45
Btw, this YoYCart website isn't fake as I first thought. The shipping is fast, China-Croatia 15 days and the customer service is fast.  :)
« Last Edit: May 29, 2024, 07:13:43 pm by M4trix »
