Hi all,
I've been working on a filter/amplifier project for a guitar, and I'm trying to figure out how to best power it, while primarily optimizing for operating time, and size/weight of the solution.
The circuit can operate on a voltage range from 5.5V to 1.8V (though the performance is better if the floor is around 2V instead of 1.8V). At 4.5 voltes, the circuit draws between 1 and 2 mA, (so a power consumption of about 9mW in the worst case).
I am aiming to have this circuit operate off of battery power for at least 100 hours, and am attempting to find a battery/voltage regulator solution which optimizes the operation time, and the size/weight of the design.
Currently, I am powering the circuit off of 3AA batteries, in series, but I'm wondering if anyone has thoughts/opinions on using a boost converter with 2AA batteries, or a buck converter with a 9V battery, to meet the 100 hour requirement at a reduced weight/volume, and if so, if there are any recommendations for good parts (optimizing for low part count and low ripple).
If there are any more details that would be helpful to this conversation, please let me know. I don't have permission right now to share the schematic of the device being worked on, but I can certainly share more particular details.
Thanks for your thoughts/opinions/help,
- Omega Glory
