I assume that you are using the 1M ohm input resistor
From the details posted on the website ...
The voltmeter can also be configured to measure different voltage ranges and display higher voltage resolution. Replacing 1M with 100K resistor will allow to measure 0 – 19.99V voltages with 0.01V (10mV) accuracy.
