Author Topic: Shunts  (Read 1272 times)
Offline PsychoMasterTopic starter
Shunts
« on: May 25, 2015, 02:48:29 pm »
Hi Folk
I have bought some ammeters off Ebay that require 75mv shunts.Well the ones supplied are useless
to the meters and I am asking what resistance is a 75mv shunt? How did they come up with that,where is 75mv relevent? How do I turn this into ohms?
                            Thanks
Offline AlfBaz
Re: Shunts
« Reply #1 on: May 25, 2015, 03:02:05 pm »
It'll be 75mV at x Amps. You then use ohms law. To find out how many amps it is put 75mV of the meter and see how many amps it reads
Offline DanielS
Re: Shunts
« Reply #2 on: May 25, 2015, 03:03:50 pm »
An analog gauge has a full-scale current/voltage and the shunt is whatever resistance you need to have the meter's full-scale voltage at the desired full-scale current.
Use a low-current/voltage power source, step it up slowly until you get full deflection, subtract that current from your max range, divide the full-scale current by the remainder of the current, that gives you your shunt resistance.
