I'm working on a way to measure the amount of water in a container.
The container is transparent, has no lid, and is made of glass or plastic. It holds 3 liters = 101 oz and stands on a tabletop mostly.
But, due to various challenges, I would prefer to measure the volume from beneath. ( To avoid dipping a MPXx2051 or float into the water)
Using a strain gauge is def. a viable option but I would prefer to have a sealed enclosure with no external moving parts.
Requirements for accuracy and precision are quite low. If I have to present actually numbers, I would say that a resolution of around 100 ml. with a +- 10 ml accuracy would suffice.
Possible solutions are:
** Updated ** A. Use a Sharp GP2Y0A41 or similar and hopefully manage to detect the water level. Will try this within the next couple of weeks.
B. Capactive sensing on the outside of the container. This solutions violates the desire to only monitor from beneath, but could be a preferable solution to weight cells. // Thanks to: forrestc, and larsdenmark for the suggestion.
C. Container resonance? Is this viable, also in plastic containers?
D. ideas?
Let me hear what you think
