Author Topic: using TWO Sanyo LB1641 Bidirectional motor drivers to drive bipolar stepper?  (Read 1294 times)
Offline dentakuTopic starter
I have these two old Sanyo LB1641 Bidirectional motor drivers I found somewhere. http://pdf.datasheetcatalog.com/datasheet/sanyo/ds_pdf_e/LB1641.pdf
I was wondering if it would be possible to drive a 4 wire Bipolar stepper motor using TWO of these to create the correct sequence (one for each winding).
I tested them both and they can run a little DC motor in both directions depending on which of the two IN pins is high and low. I know everyone uses the L297 or something similar but I just though this was in interesting experiment.
question regarding the datasheet: On page two it says...
Input level
1 : 2.0V or greater
0 : 0.7V or less
That's fine, I'm assuming that IN1 and IN2 register a HIGH if you give them 2V or higher and LOW if lower than 0.7V.
QUESTION: What tells me the maximum voltage and current that IN1 and IN2 (pins 5 and 6) can withstand?
« Last Edit: January 31, 2015, 05:47:02 pm by dentaku »
