Author Topic: Water Tank  (Read 856 times)
Offline gsingh11Topic starter
Water Tank
« on: January 27, 2023, 02:49:51 am »
I am creating a water tank in which water is controlled by a microcontroller that uses an ultrasonic sensor to measure the depth of water. My idea was to fill and empty with a single pump. but bidirectional pumps are rare or expensive. so, decided to go with 2 pumps . 1 to fill and 1 to drain. I was using a dc wall adapter to give 12 volts to the pump, which has an output current of 6A. But now I am using 2 pumps so a single pump will use around 6A of current. I am not able to find any wall adapter that gives more than 6A. What can be the solution for it?
Offline xrunner
  • hp>Agilent>Keysight>???
Re: Water Tank
« Reply #1 on: January 27, 2023, 02:53:20 am »
Just get a bigger power supply (not a wall wart). Plenty of 12V supplies for sale that output, say, 10A for little money (check Ebay, etc.)
Re: Water Tank
« Reply #2 on: January 27, 2023, 02:55:37 am »
I cant use it because I am making a college project. They didn't allow me to use a power supply.
Offline pqass
Re: Water Tank
« Reply #3 on: January 27, 2023, 02:56:04 am »
Any spare/second hand [personal computer] ATX power supply can provide plenty of amps for your application.
Offline themadhippy
Re: Water Tank
« Reply #4 on: January 27, 2023, 02:56:09 am »
dont fill whilst draining
Re: Water Tank
« Reply #5 on: January 27, 2023, 02:59:52 am »
I can do that. Does a pump draw more current when it starts? So, it won't go beyond the rating?
Offline pqass
Re: Water Tank
« Reply #6 on: January 27, 2023, 03:01:58 am »
It will but depending on the power supply, the voltage may just sag for a moment on startup or trip-off.
You won't know until you try it.
Offline james_s
Re: Water Tank
« Reply #7 on: January 27, 2023, 04:25:26 am »
Do you need to run both pumps at once? If not then it doesn't matter if you have 1 pump or 100 pumps, if you only run one at a time the draw will be whatever one pump draws. Any motor will draw a momentary surge when it starts up but it should be minimal, most power supplies will tolerate a brief overload.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: Water Tank
« Reply #8 on: January 27, 2023, 07:37:16 am »
then you are doomed to stone age power generation technology that doesnt involve electrons flow.. wall wart is a type of power supply... btw you can make the said standalone psu to tuck on the wall using some diy/hack adaptation so it will look like an absurdly large wallwart... btw, another option to using 2 separate pumps for fill and drain.. you can use electronic valves piping to redirect water in h-bridge like configuration, so avoiding nonsensical condition, fill and drain at same time, and double psu wattage requirement. Ymmv
Offline DavidKo
  • Country: cz
Re: Water Tank
« Reply #9 on: January 27, 2023, 08:06:35 am »
Can you use aquarium pump?
Online Njk
  • Country: ru
Re: Water Tank
« Reply #10 on: January 27, 2023, 06:24:00 pm »
It should not be a problem to generate enough energy in a student community. Think big.
https://www.humanpowerplant.be/human_power_plant/human-powered-student-building-plans.html
Offline cantata.tech
Re: Water Tank
« Reply #11 on: January 27, 2023, 08:02:58 pm »
Use thinner tubes, that will mean that you pump less water and that requires less current.
