I don't think the AD8052 is such a good choice for the output. I would preferr a SO8 case and possibly higher supply voltage. With the output amplifier, it may not be such a good idea to use a dual OP, as power dissipation may be the limiting factor, at least at higher supply voltages. So cooling the chip can get important.
Haven't done the thermal calculations yet but that MSOP-8 package loaded with two op amps will probably not cut it at maximum output voltage & maximum offset. Two single op amps in SO-8 packages will probably be enough but I have to do the math first.
If I want 20V
PP at the output I'll need a +/-15V supply, won't need rail-to-rail (within a few tens of milivolts) output amplifiers but the power dissipated will be higher so that's why I'll stick with 5V
PP and maybe +/-7.5V supply. Output offset will be adjustable between +2.5V and -2.5V when the output is up to 5V
PP and fixed to 0 for anything higher, up to 10V
PP. Regular output stage op amps should be within limits.
EDIT: Found
AD826 as a potential output driver. There's also the
THS4082 but that's pretty expensive and the
THS4062 in a MSOP-8 with an exposed pad which will help with getting the heat away from the die and into the PCB at a slightly higher price than the AD826, all of these are available at
TME. I'm trying to avoid Farnell or RS Components because although they stock more types of parts the prices are higher than TME.
I don't see any application where I might need more than 5V
PP with offset.
Also the way of combining the signals is even simpler than in the application note: its two independent identical amplifiers with 100 Ohms each to give 50 Ohms output impedance. The signal for amplitude control and possibly DC control could be from two separate higher value resistors.
How would that DC control look like?
