Wavetek Function Gen model 23 worth buying ? this will be my first one .. price shipping and all about 70 us dollars
specs
12 MHz Synthesized Function Generator
Form Factor Benchtop
Number of Channels 1 ch
Waveforms (Sine, Square, etc.) Ramp,Sine,Square,Triangle
Minimum Frequency 0.01 Hz
Maximum Frequency, Sine wave 12 MHz
Maximum Frequency, Square Wave 12 MHz
Maximum Frequency, Triangle Wave 12 kHz
Maximum Frequency, Ramp 12 kHz
Frequency Accuracy 0.05 %
Minimum Output Voltage 0.01 V
Maximum Output Voltage 10.2 V
Waveform Resolution 4 digits
Output Accuracy 1 %
Output Impedance 50 Ohm
Modulation AM,FM,SCM,VCG
Trigger Modes Burst,Continuous,Gate,Trigger,Toggle
Wavetek 23 Programmability/Connectivity
User Interface Proprietary
Wavetek 23 Compliance
CE Compliance Not on file
UL Compliance Not compliant
Wavetek 23 Power Requirements
Input Power Universal (Auto Sense and Switch)
Wavetek 23 Physical Dimensions
Width 211 mm(8.3 in)
Height 85 mm(3.34 in)
Length 305 mm(12 in)
Weight 4 kg(8.81 lb)
