I picked this up recently in good cosmetic condition. The owner said there was no spools with it but i did find a complete roll on the take-up. A mystery for later. Dividing the project into Electronic and Mechanical. I worked mechanical first which was more of a complete disassembly, cleaning and oiling than anything else, only minor repairs.
Mechanicals rebuilt tested and adjusted
The electronics would need more work than the mechanicals. Id thought a tube overheated [convection not electrically] the output transformer, but tested in spec
When i tested the tubes, the 6x5 was completely shorted I knew the power transformer ate it. I really knew it when testing the motor and the unit was pulling 200W without a rectifier.
The center tap on HV was internal, non fuseable,a crappy design
Ive pulled enough windings to do the maths and evaluate the values, waiting for the new wire order to arrive.
