The first generation Fluke 1AC-AI VoltAlert testers (released 10/2009, sold through 2/2010) were
recalled "The testers can fail to give an indication of live voltage..." Second generation Fluke 1AC-II VoltAlert testers are OK.
FYI latest Klein Tools Non-Contact Voltage Tester Model NCVT-1 is
recalled (almost 1.8M units 6/2021) on/off button gets stuck. Low end manufacturing in china is surely worth it.
What I got for $1 is a (defective) Fluke knockoff which needed the probe fixed. I'll use it when in electrical panels that have multiple sources, a quick check for if power is off everywhere. Of course I use a multimeter when in there.
OP can calculate (or prototype and measure) how much capacitance is required for the sensor. I imagine a few turns of insulated wire wrapped on a mains live wire would be good.
The approach using an MCU (like multimeters with non-contacting alert) are likely just a CMOS gate input looking for transitions.
