I have this idea to make a device with a (cheap!) ip20 or ip65 enclosure protecting the pcba from direct weather influences so the pcba will not be wet, but it can be damp.
The pcba will be protected using conformal coating, but there will be a small 10pin board to board connector for an optional small io board.
My problem is the board to board connector: how can i protect that from oxidation in the long run?
I looked at dielectric grease but i do not have any experience with that. Would that work in the long run?
Also, what b2b connector is suitable for protecting with dielectric grease (i assume small pin-holes are not suitable) ? Any suggestions?
thanks
