Thanks Balaur
I will start working on this new project about making my own home made (ESR) Meter,
in few days from now, my bench space is currently occupied.
Due the fact that I am currently working on a B&O TV set, I had the chance to check about 60 electrolytic capacitors,
I discovered that the small ones like 0.47uF to 10uF, are the most " sensitive group " about indicating a damaged.
The Agilent DMM U1272 did a great work, and even if it rared at 10.000 uF it managed to measure up to 11.200 uF at easy.
One last general question , due the fact that I own one tone generator that it has a square wave output up to 25KHz,
is there any way, to work out with it , in combination with a DMM and get similar readings , like to was an dedicated ESR meter ?
