sv manual page 22
https://res.cloudinary.com/iwh/image/upload/q_auto,g_center/assets/1/26/Tektronix_TPS2000B_Digital_Storage_Oscilloscope_-_Service_Manual.pdfExternal DC Input
Table 6: External DC input Characteristic Description
Voltage 15 V, ±1 V
The input is not protected from the electrically harsh automobile electrical system. Operation
from a vehicle requires a specifically designed external power supply.
Typical Power draw from External DC input:
2 channel models, charging a battery: 21 W
2 channel models, no battery: 13 W
4 channel models, charging a battery: 30 W
4 channel models, no battery: 18 W
Charging only, instrument OFF: 28 W
Current consumption
Maximum power draw from AC line by AC Adapter, 36 watts
Connector type 2.5 mm male. Use a mating connector with a 2.5 mm barrel hole.
Center conductor: positive
Outer conductor: negative
I would say 2.5 amp is ok, even 3 amps .... to give good margin, and the adapter will heat less ... it seems the maximum wattage is 30 watts, witch is 2 amp
