Author Topic: What can I do to increase the current value?  (Read 814 times)
Offline oppelTopic starter
  • Country: tr
« on: December 26, 2023, 01:57:00 pm »
There is a laser installed in the aircraft system. Sufficient current cannot be supplied to this laser in time. As the current value decreases, the voltage value also decreases. Is there a circuit (PCB) that needs to be installed or anything else that can be done to increase the current value in this system?
I would be happy if you share your valuable thoughts with me.
Offline donlisms
Re: What can I do to increase the current value?
« Reply #1 on: December 26, 2023, 06:55:54 pm »
Huh?
Offline coromonadalix
« Reply #2 on: December 27, 2023, 03:03:25 am »
same here
and aircraft have regulations,    find something suitable ....
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #3 on: December 27, 2023, 07:16:21 am »
please will you stop posting about the same thing again and again, it will make you no friends.
