Author Topic: What can I do with 400 555s?  (Read 5130 times)
Offline texaspyro
Re: What can I do with 400 555s?
« Reply #25 on: April 01, 2019, 04:33:45 pm »
Any ideas what to do with 30,000 2N7000's.   Got 12 reels of 3000 pieces from the same place / price as the 555's.  Sold a couple of reels...
Offline schmitt trigger
  • Country: mx
« Reply #26 on: April 01, 2019, 05:08:59 pm »
30,000 units? WOW! You may try to further sell them.
Offline bitseeker
« Reply #27 on: April 01, 2019, 05:25:55 pm »
If more people jump in with all of their inventory overages, you can join forces and build something truly spectacular or downright scary. ;D
Offline Richard Crowley
  • KJ7YLK
« Reply #28 on: April 01, 2019, 05:38:03 pm »
At those prices those 555s and 2N7000 are hardly worth re-selling.  The shipping costs more than the goods.
But it gives me a good idea for a similar firefly project.
I've got over a hundred 18650 cells that I have reclaimed from discarded laptop batteries.
I can create a small PC board with all the components and a couple of 18650 cells.
And put them into one of these plastic boxes.  Then have some "firefly building-blocks".
Offline jayeyeTopic starter
  • EE-turned-CS, security/networking/embedded-systems
« Reply #29 on: April 04, 2019, 06:15:54 pm »
Order another 155 555s, so you'll then have exactly 555 555s!  ;D
Hahahah... almost worth spending USD 8 for that :)
« Reply #30 on: April 04, 2019, 06:16:48 pm »
Stocking stuffers for 19 of your friends. I'm assuming you still want the first 20 for yourself.
If I do that this year, I won't have any friends the year after :)
Offline bitseeker
« Reply #31 on: April 05, 2019, 02:40:56 am »
Time to make new friends! :-DD
Offline RoGeorge
« Reply #32 on: April 06, 2019, 10:56:58 am »
Offline soldar
« Reply #33 on: April 06, 2019, 12:37:03 pm »
When your done with that let me know what to do with 2.5 pounds of Neon Lamps (NE2)…
Maybe try some surplus dealers?
Also, as has been suggested, schools.
I am sure many of us would take some if postage did not cost more than getting them direct from China.
A lot of us have stocks of things we have no use for but do not know how to put to good use.
Offline drescherjm
« Reply #34 on: April 06, 2019, 01:48:29 pm »
BTW, I purchased a dozen 555s last week to try out some of these ideas along with a few of the basics.
I have BS degrees in CS and EE both in 1996. Since this time I have worked for the same medical imaging research team primarily as a programmer. Now at 47 I am trying to get back into electronics projects.
Offline drescherjm
« Reply #35 on: April 06, 2019, 01:51:31 pm »
You can do 133 of these:  https://www.instructables.com/id/Fizzle-Loop-Synth-V3/
 ;D
I think I would have to try this when the wife is out. I can imagine her reaction to the noise...
« Last Edit: April 06, 2019, 01:53:34 pm by drescherjm »
Online Ian.M
« Reply #36 on: April 06, 2019, 04:34:39 pm »
Jayeye:"What can I do with 400 555s?"
A Class D bridge tied load stereo amplifier: 15W per channel into 4 ohm load could use 84 of them
Lineup per channel:  One 555 as triangle wave generator, one as comparator (low Z audio in to CV pin) to generate a PWM then 20 as inverting buffers, and 20 as non-inverting buffers, with current sharing resistors in series with each output to combine them into a pair of inverted and non-inverted PWM outputs good for >3A.
Combine that with 2x RoGeorge's suggested 'Synth' and you are up to 90 555's used,   Build four units for the kids of your least favourite colleagues or ex-friends and you'll be universally hated by their parents, and *still* have 40 555's left for your own stock.
« Last Edit: April 06, 2019, 04:40:46 pm by Ian.M »
Offline bitseeker
« Reply #37 on: April 06, 2019, 06:07:25 pm »
Offline james_s
« Reply #38 on: April 06, 2019, 09:42:32 pm »
Steve
You could give them to me :)
NE-2 lamps are great for nightlights, relaxation oscillators, trigger tubes, and all sorts of applications where an LED is too boring.
« Reply #39 on: April 06, 2019, 09:56:31 pm »
This is the answer to the neons question:
Offline james_s
« Reply #40 on: April 07, 2019, 02:14:13 am »
That's awesome, I wonder if those are standard NE-2's though or trigger tubes? A while back a friend of mine played with a NE-2 based ring counter and found it to be a bit fiddly. Ambient light levels would affect triggering and the characteristics changed as the lamps aged. It's possible that carefully designed it would work well.
