Author Topic: How to create pin diagrams?  (Read 6236 times)
Offline zaptaTopic starter
« on: December 19, 2014, 06:31:47 pm »
Pin diagrams like this one are very popular. Are that tools that make it easier to create them?
Offline Mad ID
Re: How to create pin diagrams?
« Reply #1 on: December 19, 2014, 07:37:53 pm »
You can do it in MS Word or in MS Visio
« Reply #2 on: December 19, 2014, 07:46:57 pm »
Thanks, Is was hoping for a more specialized tool.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: December 19, 2014, 07:51:38 pm »
You could use a TABLE in a variety of preferred environments (Word, Excel, HTML, LaTeX...), and add the lines and boxes as border or graphic elements.  Specifically for LaTeX, there's likely a PGF/TikZ package that draws tables like this (even tabu alone will get close, but may not handle the bubble shaped outlines directly).
You could also do worse than make partial or complete drawings in your preferred EDA environment.  Most provide graphical primitives and a fixed grid referenced layout.  Some schematic environments aren't as quantitative, but PCB environments can usually be used to draw proper scaled mechanical drawings, with dimensions and everything; certainly suitable for a diagram like this, though perhaps a bit droll (have fun getting colors on that .DXF).
Seven Transistor Labs, LLC
Offline Alex Eisenhut
  • Place text here.
« Reply #4 on: December 19, 2014, 11:55:59 pm »
Paging Don Lancaster! We need you to hand-code some Postscript over here!
Offline T3sl4co1l
« Reply #5 on: December 20, 2014, 03:26:54 am »
:-DD
I've read many a Hardware Hacker and Tech Musings... never wrote a character worth of PS though.
Offline Richard Crowley
  • KJ7YLK
« Reply #6 on: December 20, 2014, 03:37:38 am »
Like what exactly?
That is trivial to do in MS PowerPoint.  I have done it a few times.
« Reply #7 on: December 20, 2014, 05:20:13 am »
I ended up drawing it with Libre Office (free and OS agnostic, os a good for this OSH project). Will insert later the actual board picture.
Source file and svg rendering here https://github.com/zapta/arm/tree/master/pro-mini/www
« Reply #8 on: December 20, 2014, 05:24:16 am »
Like what exactly?
Don't know, something that already understands the general format, takes care of formatting and alignment and just requires the core data. Can be GUI based, can be text based. Similar to that specialized signal timing diagraming tool that was mentioned here once.
  • Place text here.
« Reply #9 on: December 27, 2014, 10:50:22 pm »
https://en.wikipedia.org/wiki/DGML
maybe something like this? Check out the dot language too.
Offline DonEduardo
  • If it doesn't do exactly what you want, Make It.
    • If It Doesn't Do What You Want, Make It
« Reply #10 on: December 28, 2014, 02:58:25 am »
Which tool in Libre Office did you use? Draw?
If it doesn't do exactly what you want, Make It!
https://www.youtube.com/user/DonEduardo954/videos
« Reply #11 on: December 28, 2014, 03:30:12 am »
Yes, the source file is on github. The grid is your friend ;-)
https://github.com/zapta/arm/blob/master/pro-mini/www/pin_out.odg?raw=true
« Reply #12 on: December 28, 2014, 03:34:04 am »
Thanks. I used the dot language in the past for program generated graphs, you defined the nodes and their relations and it automatically lays out the graph.
For this application I was hopping for something more high level and application specific. E.g. define the center image, define labels on both side using let's say row/column notation and basic formatting (e.g. color) and the tool would do the rest.  This style of pinout diagram is so popular that I am surprised that such a tool does not exist.
Offline DonEduardo
« Reply #13 on: December 28, 2014, 03:42:46 am »
Thanks. Just grabbed a copy of the file. Looks great. Have never used Draw yet. Might be just what I need for documenting modules I've purchased from eBay that don't have good datasheets and I end up figuring it out by experimentation. That's fine for a couple months but when I need to go back a year or so later I can't remember what I did to get things working. Thanks for the tip.
  • Place text here.
« Reply #14 on: December 28, 2014, 05:29:14 am »
There's also LibreOffice Basic, although I find the documentation obtuse.
tools -> macro -> organize macros-> libreoffice Basic
https://forum.openoffice.org/en/forum/viewtopic.php?f=45&t=46682
