Gday
I have few
SAMSUNG SCM-2271P modules from blown up PTZ cameras.
Those have zoom lens, the module is controlled via RS232C in TTL.
I happen to also have USB/RS232TTL modules from eBay.
I'm little inexperienced in this territory, how would you start talking to the camera from a PC?
Some technical:
the module has 6pin connector -VideoGND / Video / GND / +12 / TXD / RXD (gives great picture)
the Tx pin pulls up tp 3V3 on powerup, rx stays on 0V
the whole PTZ cameras usually have large OSD menus, usually controlled via RS485 Pelco protocol - there are commands for 'open menu(save preset95)', 'close menu(save preset94)', select(iris open), back(iris close), up, dn, left, right
I would imagine the OSD is in the mainboard that blew up, however the module itself should listen for zoom commands.
I'd like to be able to control the zoom on this module, just for fun.
any ideas..?
