Author Topic: What is present definition of Litz wire?  (Read 3495 times)
Offline mag_thermTopic starter
« on: January 01, 2021, 03:59:53 am »
I read on another thread about a product Litz Type TEX-ELZ consisting of 6 cores of 0.1 mm diameter,
 wound around a copper core as in the diagram.
I don't agree with some of the wiki definition of Litz wire, but  do agree with this part:
"The result of these winding patterns is to equalize the proportion of the overall length
 over which each strand is at the outside of the conductor."
(Search wiki "Litz wire")
Can 6 Cores spiralling  , in any warp,  around a central core  meet this definition?
Can anybody in the cable industry on here comment?
Offline bob91343
Re: What is present definition of Litz wire?
« Reply #1 on: January 01, 2021, 06:59:07 am »
This stuff has been around for about 100 years.  The essential parts of it are that each strand is insulated from the rest and that the twist is such that every strand spends as much time as any other on the outside of the wrap.
I don't know if there is a central core; I don't think so.  It's created by a machine.  Of course when you connect it you have to strip every strand and solder them all together at each end.
I probably haven't answered your question satisfactorily but did the best I could.  I would have to dig into one of Terman's books to get more information.
Offline Bud
« Reply #2 on: January 01, 2021, 08:14:53 am »
Never seen Litz wire wound around a solid center core. If there was a core it was nylon strands that made the wire soft  and flexible.
Offline BravoV
  • +++ ATH1
« Reply #3 on: January 01, 2021, 08:30:59 am »
Probably just for the audiophoolery related.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: January 01, 2021, 03:24:42 pm »
Right, a center wire does very little duty in such a build.
I've also taken apart some cable, that looked to be the same build, with each component itself being litz of some size (like 3 x 5 x 22 or something, I don't remember).  So they went to the trouble of using proper litz sub-cables, but wound them around a central one that does nothing, or at least much less than it ought to.  Go figure.  It probably wasn't the most well-considered piece... it may've been China or Taiwan sourced, dunno.
NEWT at least doesn't recommend such builds, and typically designs these sorts of cables with 3-5 units in the final braiding step (so none get stuck in the middle).
They do have some strange (in the useful way) builds suggested in their catalog -- namely, cables built with rope (insulating fiber) spacers, to further reduce current density and capacitance, for applications where that's advantageous (probably stuff like RF tanks for big transmitters).
As for definition, I think it properly has to be multiple units braided.  Just a pile of strands, doesn't generally perform all that well (though still better than bare stranded, which is itself noticeably better than solid, FYI).  Doesn't matter all that much for small strand counts (like 7), but once you're into the dozens, it starts to matter more and more.  The strand size also needs to drop as you get into large counts, as the proximity effect upon every strand dipping into the middle of the cable becomes substantial.
So, a typical pattern might be to braid 3-5 units of 5-50 strands each, and 3-5 units of those and so on for larger and larger cables, as needed.  The biggest I've handled was... about dick sized, is the easiest way to put it.  With a flexible rubber (neoprene?) jacket, it kind of had about that feel to it, too. :)
Seven Transistor Labs, LLC
Offline BravoV
  • +++ ATH1
« Reply #5 on: January 01, 2021, 03:31:10 pm »
The biggest I've handled was... about dick sized ...
What was the size again ?  >:D
Offline madires
  • A qualified hobbyist ;)
« Reply #6 on: January 01, 2021, 04:22:02 pm »
Shouldn't it be radiophoolery? :) If the core wire is much larger than the strands it could be to increase the tensile strength of the cable.
Offline T3sl4co1l
« Reply #7 on: January 01, 2021, 04:35:05 pm »
Which is done for power transmission: often a steel core is overwound with aluminum strands, for a better compromise between strength, weight and conductivity.  (Very pure aluminum is only modestly less conductive than copper, but rather weak; and, when you're carrying thousands of amperes in an arm-sized cable, the skin effect (at mains frequency) is significant enough that the steel core doesn't see much current or magnetic field, and thus loss.  That is, the aluminum acts to shield it.)
Offline pardo-bsso
  • Country: ar
« Reply #8 on: January 01, 2021, 05:26:23 pm »
Do you have pictures or more data about how it was used?
Asking for a friend. (and myself too)
Offline T3sl4co1l
« Reply #9 on: January 01, 2021, 05:45:11 pm »
Application was wiring from inverters, to output transformer, in medium size induction heaters.  600A 150kW per inverter module, ganged as needed (scalable design), operation up to 50kHz (with derating).  Think the strands were 36AWG, not too fine, suitable for the frequency range (most builds 3-20kHz).
The flexibility was also a great aid in how they were used: inverters were joined with 0° power combiners -- these were hand-wound in the assembly, by braiding two cables oppositely through one ferrite core (which were 2-3" o.d.) on their way to the common node (transformer).
Use was simple, strip back the rubber jacket, take a suitable (#000 I think) lug, crimp it (make sure all the strands are packed in there), squirt some liquid rosin in, dip in the solder pot and hold until it stops bubbling.  Litz is... just about useless without solderable enamel!
Offline LaserSteve
« Reply #10 on: January 02, 2021, 07:52:01 am »
What l think of as classic Litz is fine enameled  wire with a thin cotton or rayon braided cord wound around each strand   for strength and additional insulation. I have childhood memories of how difficult it was to free up and solder all the strands, without breaking them. This was in various shortwave radio kits. It had a definite look of being made on a loom. In other words, the strands were isolated from each other, with the equal length twists.
"Litzendraught"
Steve
« Last Edit: January 02, 2021, 08:05:02 am by LaserSteve »
"Programming is more than an important practical art. It is also a gigantic undertaking in the foundations of knowledge"
Adm. Grace Hopper
Offline BravoV
  • +++ ATH1
« Reply #11 on: January 02, 2021, 08:39:24 am »
Bought these while ago, left spindle is 80 strands x 0.1mm wires, and the right one is 60 strands x 0.08mm wires, did counted the strand count just for curiosity under microsope.  ::)
The right one with white jacket is PITA to clean and solder, while the left one was easy, just used a gas lighter to burn off the the tip and all strands can be solder wetted and easily solderable.
« Last Edit: January 02, 2021, 08:42:55 am by BravoV »
Offline bson
« Reply #12 on: January 03, 2021, 09:57:23 pm »
That seems very unlikely.  If so the natural choice would be some sort of composite - fishing line for example has 5x the tensile strength of steel, is a whole lot more flexible, lighter weight, and isn't conductive.  Copper and aluminum are even worse, and both are conductive to boot.
Offline madires
« Reply #13 on: January 04, 2021, 09:50:53 am »
Good point! Another possibility could be that the core wire is meant to make the cable less flexible.
Offline jonpaul
    • IEEE Spectrum
« Reply #14 on: January 04, 2021, 11:50:28 am »
Hello all:
Litz strands are available  insulated with  solderease, nylease, and other "enamel" to insulate each strand.
Cotton or nylon fibers wrap the bundles or the entire cable.
Litz  reduces the skin effect and proximity effect, most effective 250 kHz-10 MHz depending on wire gauge and current.
The RF effective resistance depends on the strand diameter, frequency and the weaving so each strand moves from inside to outside.
Indeed spécial wire fab machines are used to fabricate Litz.
Notice that merely bunching separate wire strands togather is NOT true litz!
For terminating, we use a hot solder pot, fresh flux, dip till fabric wrap and enamel insulation burns off.
Remove and clean off residue with x-acto knife or sandpaper.
Retwist strands, and resolder in solder pot.
Finally, foil conductors can be a better solution.
Bon Voeux Année,
Jon
The Internet Dinosaur..
passionate about analog electronics since 1950s
The following users thanked this post: BrianHG
Offline ali_asadzadeh
« Reply #15 on: January 04, 2021, 12:07:27 pm »
Dose someone happen to know a Chinese supplier of the Litz wires?
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline jonpaul
    • IEEE Spectrum
« Reply #16 on: January 04, 2021, 02:50:31 pm »
Would doubt spec of any Chinese wire for professional applications.
Suggest to BUY AMERICAN OR EUROPE
CHINESE= CHEAP,  SLOW, NO RESPONSIBILITY
J
Offline SiliconWizard
« Reply #17 on: January 04, 2021, 04:32:35 pm »
Well apart from what's been already said, you'll find what looks like relevant info on Wikipedia: https://en.wikipedia.org/wiki/Litz_wire
(haven't read the article thoroughly but what I've read looks accurate enough.)
Also, not sure what you mean by "present definition". As bob91343 said, it's pretty old "tech" already, and I see no reason why the definition would have changed.
As has been said above, its effectiveness decreases past a certain frequency (depending on the specifics of the wire) due to parasitic capacitance, which can become a serious problem with wires made of a bunch of isolated strands.
« Last Edit: January 04, 2021, 04:35:38 pm by SiliconWizard »
Offline tooki
« Reply #18 on: January 04, 2021, 11:29:52 pm »
The only defining characteristic is that each strand is individually insulated.
Also, as an FYI, the word "litz" comes from German, where "Litze" means simply "stranded wire", without the individual insulation. The German name for litz wire is "HF-Litze", i.e. "high frequency stranded wire".
« Reply #19 on: January 05, 2021, 12:20:04 am »
Indeed. The OP didn't say exactly what it was that they didn't agree with - or it was not completely clear, so it's hard to comment further - all we can say is as far as the definition part goes, the Wikipedia article seems to do a good job. The definition is pretty basic as you just said. Now if there are furthers points in the article not directly related to the definition, but to Litz wire design specifics, that's a different story.
The question "Can 6 Cores spiralling  , in any warp,  around a central core  meet this definition?" - I can't personally comment on whether this particular design would be good and for what purposes, but if said "cores" are insulated from one another, then I don't see why it wouldn't qualify as Litz wire.
