Hi folks,
I found those
±1 mm calipers on ebay and thought they are cheap to get my hands on them for a project I'm working on.
Unfortunately, they turned out to be inductive halfbridge calipers, but I was expecting them to be LVDTs in the first place.
There are these old panel meters to display the position, but even used they cost an arm and a leg and are purely analog without access to the electrical position information. I've searched the web in the hope to find some ideas or solution how modern technics can be used to excitate and read out the signals, such as the
digi 3plus, which costs a fortune compared to the calipers.
But I couldn't find anything suitable. Anyone here has an idea how they work or can come up with a good suggestion or even a DIY / OpenSource solution?
What I could find out so far is, that beside the changing amplitude with position, they seem to show a position dependent phase shift for frequencies <10 kHz. At 10 kHz and larger only the amplitude changes with position.
Every suggestion is welcome, be it an RPi solution with an appropriate shield or microcontroller solution. I'd like to have a
resolution down to ~100 nm, just for completeness.
-branadic-
