Well, it says it right in the datasheet "The Write Protect (/WP) pin can be used to prevent the Status Register from being written." That's all it does. The consequences of that you can figure out by reading the description of the Status Register.
Just pull it high, and forget about it, you will be able to do whatever with the flash.
