Probably you can make use of the fact that if:
y = ex
then
dy/dx = ex = y
Therefore if you set up an op amp in an integrating configuration and make it integrate its output, you will get exponential growth.
Most likely you will need suitable gain in the circuit to obtain the right time scaling.
