Author Topic: What is this DOT OR gate in this 8b/10b article?  (Read 1102 times)
Offline DmeadsTopic starter
  • who needs deep learning when you have 555 timers
« on: June 12, 2020, 09:53:21 pm »
Hey! working on 8b/10b in Verilog. Im using the original 1983 IBM article to structurally code it. Cant seem to find what this gate is (see pic)
All is says is " OR DOT"
any ideas?
Here is the original article. The gate shows up on pg. 11
https://opencores.org/websvn/filedetails?repname=1000base-x&path=%2F1000base-x%2Ftrunk%2Fdoc%2F01-581v1.pdf
« Last Edit: June 13, 2020, 12:25:43 am by Dmeads »
Online ataradov
    • Personal site
Re: What is this gate in this 8b/10b article?
« Reply #1 on: June 12, 2020, 10:41:38 pm »
I've heard a name "Dot OR" for wired-AND circuit where AND is implemented by connecting two open-collector outputs together. I'm not sure if that makes sense in this context.
Here is a description https://en.wikipedia.org/wiki/Wired_logic_connection
Alex
The following users thanked this post: Dmeads
« Reply #2 on: June 12, 2020, 11:14:40 pm »
Okay I did some digging and I found the authors used Motorola's MECL (Monolithic Emitter Coupled Logic) 10000 series chips to implement the design so ya, you're probably right. Thanks!
Offline jmelson
« Reply #3 on: June 13, 2020, 02:18:44 am »
In ECL, it is actually a "wired OR" as the gate outputs pull up when active, and let the pull-down resistor control the logic level when not active.  So, if either gate output is active, the logic level gets pulled up to a '1'.
Jon
Online fourfathom
Re: What is this DOT OR gate in this 8b/10b article?
« Reply #4 on: June 13, 2020, 02:35:40 am »
Logically it's a NOR gate.
out = !(A | B)
We'll search out every place a sick, twisted, solitary misfit might run to! -- I'll start with Radio Shack.
Offline helius
« Reply #5 on: June 13, 2020, 03:37:22 am »
Each AND gate (the symbol that looks sort of like an 'A' is a ∧) has two inputs and two outputs. The inputs are inverted, indicated by a small triangle at the end of the wire. In the most common symbology this is indicated instead by a small circle on the wire. Only the bottom output is inverted, and the top output is normal. By De Morgan's rule, this is equivalent to a NOR gate (for the top output) and an OR (for the bottom output).
The Wired-OR of the normal outputs of the two AND gates is an EQV of a and b. It is true iff A=B.
This kind of two-output, one-normal one-inverted is a natural use of ECL since it is current switching logic. Current is switched to exactly one of two possible paths.
« Reply #6 on: June 13, 2020, 04:16:17 am »
hmm. wierd. Okay so just to reiterate (so I dont screw up my code more than I already have  :palm:) The OR DOT is True if A = B, and the AND gates have inverted inputs, so are like a negative AND gate. The top output is a NOR function, and the bottom output is inverted so OR.
Thanks guys, really appreciate it.
