Author Topic: What is this type of wire-connector called?  (Read 3105 times)
Offline sherrellbcTopic starter
« on: January 16, 2015, 04:33:27 pm »
I am having the hardest time finding something like this on Mouser. I have find things similar, without the screw for example, but never exactly this. Is there a generic name for this type of connector?
If you type something like PCB 2 Way Connector into Google then your search is through, but Mouser apparently has a different naming convention for these little connectors.
Examples:
http://www.amazon.com/2-way-Screw-Terminal-Block-Connector/dp/B00DSKC6TW
https://www.robotics.org.za/index.php?route=product/product&product_id=508
Offline aroby
Re: What is this type of wire-connector called?
« Reply #1 on: January 16, 2015, 04:49:05 pm »
Molex terminal blocks.
Offline 8086
    • Circuitology - Electronics Assembly
« Reply #2 on: January 16, 2015, 04:52:57 pm »
Offline LukeW
« Reply #4 on: January 17, 2015, 07:56:12 am »
I would call it a PCB-mount screw terminal block, generally.
They are commonly available in a range of different pitch, eg. 2.54mm, 3.5mm, 5.0mm, 5.08mm, 7.62mm etc.
5mm and 5.08mm are both quite common, and looks like your example photo is one of those. You should be careful not to buy 5.0mm metric if your PCB layout uses 0.2" imperial or vice versa. If you've got 2 or 3 pins on the block they can be used interchangeably, but they will be incompatible if the block is larger.
Digikey has a whole category of "Terminal Blocks - Wire to Board" - here's one typical example:
http://www.digikey.com/product-detail/en/1935161/277-1667-ND/568614
