Author Topic: What Kind of relay do I need  (Read 1607 times)
Offline MrJonnyTopic starter
« on: October 09, 2015, 04:51:52 pm »
I want to make a box that turns the hoover/Vacum on when you power the drill.
So basicly it will have 2 sockets. One for drill and one for Hoover. Cord with plug for power and a relay in side.
When drill is being used the hoover socket becomes lives and turns on.
I know how to wire a relay but unsure what kind of relay I need
http://www.ebay.co.uk/itm/AC-AC-AC-90-250V-to-AC-240V-20A-Single-Phase-SSR-Solid-State-Relay-With-Cover-/321657933903?hash=item4ae44e904f
I'm guessing this one is not the correct one, as the drill can pull around 7-10amps (I don't want to fried the relay). But 20amp load would be fine for a hoover as they are around 1000 watts so around 5-6 amps in the UK
Offline Timisthen
Re: What Kind of relay do I need
« Reply #1 on: October 09, 2015, 05:13:12 pm »
This seems a strange need you have.
But, no, the relay you listed will not work as it's rated for a control current of 2-12mA. If your drill is drawing up to 10A, you'd probably want a control current rating that goes up to at least 15A.
Quite frankly, I'm not sure that relays such as that exist. You may need a more complex control circuit. Maybe use a current transformer to sense when the drill is drawing power.
« Last Edit: October 09, 2015, 05:14:47 pm by Timisthen »
Offline ajb
« Reply #2 on: October 09, 2015, 05:58:20 pm »
You'll need more than just a relay, but you can buy this sort of thing ready made.  Here's a US version: http://www.amazon.com/DGC-PRODUCTS-IS110M-i-Socket-Autoswitch/dp/B005ELWUWG/ref=pd_sim_263_7?ie=UTF8&refRID=1NPG55VD9Z6DDRJYVS3F
Offline calzap
« Reply #3 on: October 09, 2015, 06:45:45 pm »
Hopefully, you weren't thinking of putting the relay activating terminals in series with the drill power.  There are two ways to do what you want.  One is to have an external, switched duplex outlet that supplies power to both the drill and vacuum.  The switch should be double pole and rated for the drill plus vacuum HP.  This is the simplest and cheapest way, but may be inconvenient in some cases.   As another posted, if you want to use a relay, you'll need more than just the relay.  You'll need a current sensing circuit that detects when power is going to the drill and that is what should activate the relay.  The relay should be double pole, have the correct voltage rating for activation and contacts, and be rated for the drill motor load (i.e. have a HP rating).  What you really need is a motor contactor, which is a relay designed specifically to control motors.  If you buy a premade sensor/controller, be sure it's rated for your drill and vacuum HP.
You can't just take the current rating of a relay and assume it will be adequate for motors.  They are inductive beasts with big starting and stopping surges in most cases.  The relay needs to be rated for a  motor load.
Vacuum HP is often grossly overstated on the label; you'll need to read the fine print in the manual or on the motor.  I have shop vacuums rated to operate on 15A, 120 VAC circuits, and the labels on the units state they are 3 HP or more!  The manufacturers lie by converting the starting surge current or  locked rotor current to HP and use that in their ads.
Mike in California
