Author Topic: What kind of varistor is this?  (Read 2434 times)
Offline AndersJTopic starter
« on: April 27, 2019, 10:02:36 am »
Can anyone identify this component, possibly a varistor?
"It should work"
R.N.Naidoo
Offline Andy Watson
Re: What kind of varistor is this?
« Reply #1 on: April 27, 2019, 11:02:20 am »
I would say it is a capacitor 1n5 F. The 400 V AC and peak 4kV rating, along with all the other certification logos suggest that it is rated for safe use on mains.
Offline Benta
« Reply #2 on: April 27, 2019, 11:24:38 am »
It's a 1.5 nF Mica cap for mains use.
Offline Gyro
« Reply #3 on: April 27, 2019, 11:35:36 am »
This is fun :)
It's a 1.5nF 400V AC, 4kV AC test, Ceramic.  Note that while it's certified for flamability, it's not suitable for use (unprotected by a fuse) across the mains as it doesn't have an X or Y marking.
Edit: Y2 would require 5kV test and Y1, 8kV.
« Last Edit: April 27, 2019, 12:12:31 pm by Gyro »
Best Regards, Chris
« Reply #4 on: April 27, 2019, 12:23:18 pm »
Thanks everyone.
I saw the 1n5 marking,
but it never occured to me that it could be anything but a varistor.
"It should work"
R.N.Naidoo
Offline Benta
« Reply #5 on: April 27, 2019, 02:34:57 pm »
This is fun :)
The markings say it has mains use approval for Switzerland, Sweden, Germany, US, GB, which then automatically leads to approvals for other countries, generally all of the EU. It's approved for Y and X1 use.
It's ceramic and older than 1994, where the approval markings changed (X or Y specifically marked on the part).
Offline 3roomlab
« Reply #6 on: April 27, 2019, 02:51:34 pm »
what gave that away?
the VDE triangle?
Offline Benta
« Reply #7 on: April 27, 2019, 03:11:33 pm »
the VDE triangle?
No, it's just a question of when the standards changed due to EU harmonization rules and the shift to using the ENxxxxx norms.
Here's an example: pdf.datasheet.live/datasheets-1/vishay_presicion_group/7/WKP102MCPTD0K.pdf
« Last Edit: April 27, 2019, 03:13:04 pm by Benta »
The following users thanked this post: 3roomlab, Andy Watson, Gyro, newbrain
Offline floobydust
« Reply #8 on: April 27, 2019, 04:34:45 pm »
BS 415 "Specification for safety requirements for mains-operated electronic and related apparatus for household and similar general use " withdrawn Nov. 1995
Offline Gyro
« Reply #9 on: April 27, 2019, 05:41:20 pm »
Good find on the datasheet. I must admit to being a bit puzzled to see a BS415 marking on what looked to be a relatively modern (well at least, clean) looking part.
Sadly topical.  :(
Best Regards, Chris
Offline Zero999
  • 0999
« Reply #10 on: April 27, 2019, 06:58:02 pm »
