I would like to design a carrier board for a bunch of SBC's (NanoPi Duo2) and have them connect to a switch IC on the carrier board and have it present a single RJ45 on that so I can connect them all to my lab LAN at once.
I am not hard set on a switch IC but but something like a RTL8305NB IC with 5 10/100 PHY ports.
What magnetics do I need on the board between the NanoPi and the switch IC's inputs?
If they were totally separate device's connected by cat5e there would be:
Ephy <-> Transformer <-> common mode choke <-> auto transformer <-> RJ45 <-> cat5e <-> RJ45 <-> auto transformer <-> common mode choke <-> Transformer <-> Switch IC
I assume that I can remove the cat5e and RJ45 connectors but how far can I go?
Can they just be connected together as the grounds and so voltages should all be the same?
Thank you in advance for any suggestions or pointers to more reading.
