Author Topic: AD8302 front-end  (Read 1558 times)
Offline ealexTopic starter
AD8302 front-end
« on: March 09, 2017, 04:30:59 pm »
hello
i'm planning to make a simple / low quality VNA based on the AD8302 chip from analog:
http://www.analog.com/media/en/technical-documentation/data-sheets/AD8302.pdf
the entire thing will run up to 50MHz, that's the limit of the DDS i've already built.
reading the documentation i understand that, for the best range, both inputs should be at -30dBm if both signals are equal, as the allowed input range is [0 .. -60dBm]
that will allow measuring 30dBm gain or 30dBm loss in one go.
i'm thinking of making the input stage like this:
the idea is to extend the range of measurement via SW1 and SW2:
- SW1 and SW2 opened -> 60dBm of attenuation, it can measure gains of mostly 60dBm
- SW1 and SW2 closed -> 0 dBm attenuation, it can measure DUT attenuation down to 60dBm
- SW1 closed and SW2 opened -> 30dBm attenuation, it follows the datasheet recommendation
the main problem is that i don't know how to choose the relays for SW1 and SW2 - grab the cheapest RF / small signal relay ? or look after some specific parameters ?
also, is the entire thing work trying to do ? or i should just use coaxial attenuators inserted in front of the entire thing ?
