Author Topic: LAN8720 ETH PHY Activity LED indicating only inbound traffic?  (Read 622 times)
Offline YansiTopic starter
  • STM32, STM8, AVR, 8051
« on: August 18, 2019, 11:19:46 am »
Hello,
just started tinkering with ETHernet, now completed my first hello world using a LAN8720 ETH PHY (Datasheet).
What I found interesting (and to be honest, very annoying) is that the activity LED blinks only on inbound (receive) traffic. When I for example send a packet every second, the LED does not blink, stays lit.
I think this is beyond stupid, as if I wanted to use the PHY in a device, for example a UDP streaming device, that produces 99% traffic only outbound (transmit), the LED would not indicate absolutely anything.
Datasheet of the PHY seems to confirm this stupid behavior of the LED: Section 3.8, quoute: "The LED1 output is driven active whenever the device detects a valid link, and blinks when CRS is active (high) indicat-ing activity"
Why is that? Is it normal the link/activity LED blinks only on received data (CRS, carrier sense)?
