It might be to produce a flat field in order to detect cold pixels.
There is nothing to ensure an even distribution of light over the array, so it wouldn't be a particularly flat field, but could detect dead pixels, and over time also measure any degredation by comparing previous reference images - sensors in x-ray systems can suffer damage over time due to the effects of the x-rays.
It could also be a faultfinding aid - as it has an image intensifier, having an internal light source would provide a quick test that the sensor is OK, to distinguish sensor faults from intensifier problems when all you can see is a dark screen.
Due to downtime, parts cost, dust issues etc., being able to give a quick answer to the question of whether a fault is in the camera or intensifier would be useful, certainly well worth the cost of a LED.
I wonder if there is also a LED that can fire some light at the input side of the intensifier, to distinguish intensifier faults from x-ray problems.
