We need to see the schematic, to make a full judgement. The output impedance of the potential dividers is 60Ohm and it seems plausible a low frequency op-amp, will work with that sort of power supply impedance, without any problems, as long as not much current is taken from the output.
To get a total power supply voltage of 5.5V, rather than 6V, change the lower resistor to 100R, on the negative supply. The reason why I'm suggesting to reduce the negative, rather than positive supply voltage, is because the works closer to the negative voltage, so reducing that, will have less impact.
