Around 28VAC, though you probably, unless that is a really tiny motor, will want a little more capacitance on the transformer. Current rating will also have to be around 1.5 times the full load current of the motor, unless you have some operating time limits that have the motor running at low power most of the time, and rare full power operation, though I suspect your transformer was undersized for that reason, so it was cooked nicely.
