Author Topic: Zero ohm resistor wattage  (Read 3578 times)
Offline AlfBazTopic starter
« on: December 27, 2012, 03:47:43 pm »
I want to use a zero ohm SMD resistor, its rated at 0.1W. I'd like to work out the max current but I^2*R isn't going to do it and +-1% tolerance of 0ohms to get the deviation is somewaht mute also.
Unfortunately the data sheet is a generic one for the model line, so not much help there iether.
Any ideas?
Offline c4757p
  • adieu
Re: Zero ohm resistor wattage
« Reply #1 on: December 27, 2012, 03:51:09 pm »
Well, what is the real resistance? It ain't zero...
« Reply #2 on: December 27, 2012, 03:54:08 pm »
Good question. Haven't ordered it yet and how do you work out the tolerance of 0 ohms
« Reply #3 on: December 27, 2012, 04:15:56 pm »
Normally it will be between 50 to 200 milliohms per unit, all it is is a metallised film with a set of ends. Not really a high power unit, use the ratings for the lowest value resistor in the range.
« Reply #4 on: December 27, 2012, 04:22:42 pm »
...use the ratings for the lowest value resistor in the range.
:palm: of course...
Thank you
« Reply #5 on: December 27, 2012, 05:06:50 pm »
You are not alone, i have seen many nominal zero ohm links that have been cooked by the current flowing through them.
Offline Short Circuit
    • White Bream electronics R&D
« Reply #6 on: December 27, 2012, 07:40:02 pm »
The real datasheet should mention a maximum current.
This Royalohm datsheet specifies a max working current of 2amps for a 0805 (1/10W) package.
As you can see its handles as a special case; working current instead of voltage and no tolerance specified.
