Hi everyone,
For those who may work with power electronics, specifically transformer construction, maybe you will have an answer to the following.
I'm trying to meet a very low secondary DCR target on a miniaturized transformer I'm working on. I'm considering using copper foil, but I think it will be impossible to meet the primary-secondary creepage requirements of EN60950. The bobbin winding window width is just shy of 4mm. I also need 4mm creepage for EN60950, so according to my initial analysis, I can't see how that will work. (With a larger bobbin winding dimension, meeting the creepage requirement is much easier.)
Has anyone used any kind of reinforced/triple insulated copper foil in transformer design? Does it exist? If so, how would you terminate to it (flying wires) without violating safety requirements.
I know this is pretty niche, so if you have any other ideas or input, I'd appreciate that too.
Thanks!
