So i got my second type k thermocouple.
I have tied both thermocouples closer one to each other.
Placed them in the kitchen oven ( thanks god my wife wasn't home
Since my multimeter shows a 23 degree ambiant, i used the same temperature as compensation for my hardware.
Waited a bit for the temperature to settle in the oven.
On the multimeter the temperature was stable arround 138-139 degree, while on my circuit it was 137-138(compensated with 23degrees), and raw reading was 115 degrees and 4.61 milivolts.
4.61/115 = 0.04008 uV/degree like expected.
Ok maybe, the pcb where the connections are made with the tc there was maybe +2/3 degrees due to self heating of the circuitry
But both thermocouples follow each other at different speed, but when the temperature is quite stable, both temperature readings stay close to each other +/- 1-2degree.
Seeing this i am quite confident that the circuitry itself works well.
So i really wonder how JBC deals with the self heating of the contacts inside the holder, maybe the even use a lookup table depending of the temperature range?
