The original poster was asking about rail-to-rail output stages. Most of the links that have been provided are for booster stages to extend the voltage swing.
Here is the LM10 schematic from National Semiconductor's AN-211:
The LM10 was designed by Bob Widlar, it was the first op-amp to have a rail-to-rail output stage. To obtain a rail-to-rail output it is necessary to saturate the output transistors. Saturating the output transistor can lead to other problems like over-drive recovery.
You can use the circuit to make a non-rail op-amp into a rail-to-rail circuit. (Note: this is not a mistake the outputs are taken from the supply pins on the op-amp):
The circuit has been set up with a gain of -10. This shows the output been driven very close to the rail:
If I increase the input voltage to 1.05V, to cause the output to clip I see some nasty over-drive recovery problems:
Increasing R3, can help a little.
I have attached a zip file with the LTspice model.
Regards,
Jay_Diddy_B
