Author Topic: What´s the purpose of the white gunk?  (Read 2465 times)
Offline TimNJ
Re: What´s the purpose of the white gunk?
« Reply #25 on: December 08, 2022, 01:21:17 am »
If you are inclined to use RTV from Home Depot for your electronics, try GE Silicone II, not I. But they both kind of suck though, way too soft.
Offline alanambrose
« Reply #26 on: December 08, 2022, 05:57:02 pm »
I think that it acts like a damper for high vibration circumstances. Probably the pad/solder combination by itself will work harden and crack after a while with the vibration energy. So this stuff absorbs some of the max amplitude vibration.
Alan
“A foolish consistency is the hobgoblin of little minds"
Offline arildj78
  • Country: no
« Reply #27 on: December 08, 2022, 08:42:57 pm »
Is there a video to be made here @EEVblog?
Offline gnuarm
  • Country: pr
« Reply #28 on: December 09, 2022, 08:30:34 am »
Alan
The gunk can't absorb any of the vibration, because the part isn't actually vibrating until the solder cracks... unless the leads allow movement.  Then the problem is the leads breaking, which is my guess as to what is being protected, rather than the solder joints.
Rick C.  --  Puerto Rico is not a country... It's part of the USA
  - Get 1,000 miles of free Supercharging
  - Tesla referral code - https://ts.la/richard11209
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #29 on: December 09, 2022, 07:33:52 pm »
Notice the contrast of examples: for the SMT part, leads are short and stiff, and a rigid resin is required to further secure it.
For a THT part, the leads have some length, so the part can flex against the board.  It might also have enough pins that it's rather well tied into the board, so the board itself flexes more (a potential hazard for nearby ceramic chip caps, say!).  Consider a big ETD39 laying flat with dozens of pins, and now compare to the case of something floppy, like a THT electrolytic capacitor.  The former might not need anything, while the latter might benefit most from a softer resin, as the peak deflection could still be within the elastic range (little/no lead fatigue), whereas a very rigid compound might.. tear the capacitor's skin away, or something?
Maybe that's not the best contrasting example, I've certainly seen caps glued to boards with fairly stiff glue, and at that, mainly because the layer was thin.  The skin / jacket is usually pretty tough by itself.  But you can imagine components that can't be pulled just any which way, that might be damaged if glued improperly and subjected to mechanical shock.
Conversely, soft resin on a rigid component, just doesn't do much.  It's adding a large inductor in parallel with an already small one, it does nothing.  (Note that electrical analogies are no accident, there is a perfect equivalence between inductance and mass, resistance and, erm, dashpot, and capacitance and spring.  Mechanical systems are less often reasonable to treat as lumped element equivalents, because of the fairly low speed of sound and many degrees of freedom, but it can still be illustrative of some cases.)
Seven Transistor Labs, LLC
