Author Topic: whats this transistor?  (Read 741 times)
Offline pinballtoysTopic starter
« on: May 24, 2022, 10:55:23 am »
hello all
was looking to replace this transistor but not sure what to order?
i can see its made by Vitelic and looks to be an NPN with ECB pinout but I'm struggling to find its full part number
it switches a 240V relays and suspect a MPSA42 may do the trick but the pinout is different.
Anyone have some suggestions please?
Bob
https://www.dropbox.com/s/kcb7rakxpwdmziv/transistor%20%281%29.jpg?dl=0
Online wraper
  • Country: lv
Re: whats this transistor?
« Reply #1 on: May 24, 2022, 11:00:23 am »
It's certainly has ST logo, not Vitelic.
Online wraper
  • Country: lv
« Reply #2 on: May 24, 2022, 11:03:58 am »
The following users thanked this post: pinballtoys
Online Benta
« Reply #3 on: May 24, 2022, 11:04:19 am »
Yes, ST.
More likely a triac.
Online wraper
  • Country: lv
« Reply #4 on: May 24, 2022, 11:06:29 am »
And you should have cleaned the part with alcohol. Since "B" in BV42 marking as basically invisible.
« Reply #5 on: May 24, 2022, 11:24:14 am »
thanks so much
I'm in the UK and would normally buy from RS components, but it looks like this device went obsolete some time ago!
Offline Zero999
  • 0999
« Reply #6 on: May 24, 2022, 12:20:02 pm »
Are the relays run off AC, or DC? That will enable to determine whether it's a TRIAC or BJT.
« Reply #7 on: May 24, 2022, 12:26:23 pm »
looks like mains is half-wave rectified so assume its a transistor
* IMG_20220429_0002.pdf (514.46 kB - downloaded 34 times.)
« Last Edit: May 24, 2022, 12:31:51 pm by pinballtoys »
Offline gamalot
  • Correct my English
    • Youtube
« Reply #8 on: May 24, 2022, 12:30:41 pm »
« Reply #9 on: May 24, 2022, 12:37:51 pm »
this is the circuit board I'm trying to repair, the problem being RLB is not switching on!
i thought i'd found the problem with capacitor C2 that had a high ESR but fitted new cap and problem persists
not sure how this works?
i can see that RLA is permanently on and even though half-wave supplied C1 ensure it stays on
« Last Edit: May 24, 2022, 12:43:09 pm by pinballtoys »
