Author Topic: Idea On How To Leave Laptop in Car  (Read 12016 times)
Offline bostonmanTopic starter
Re: Idea On How To Leave Laptop in Car
« Reply #25 on: December 15, 2022, 02:45:44 pm »
maybe you can learn how the car's electronic protected from it? how the ecu is sealed inside enclosure?
This is more about the battery which isn't removable. The electronics should be fine in all temperatures.
As for using a cooler. I thought of this and seems anything will need to be brought in first unless I go with the handwarmer idea someone mentioned.
