Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Where can I get cable assemblies like this?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Where can I get cable assemblies like this? (Read 741 times)
rea5245
Frequent Contributor
Country:
on:
March 10, 2020, 04:50:54 pm »
I just bought an LA104 handheld logic analyzer and it comes with a cable assembly with a 0.1" rectangular connector on one side and female Dupont wires on the other, i.e.:
Is there a place to buy these off-the-shelf, with different numbers of wires? I'm not even sure what to Google for.
Thank you,
Bob
Logged
Mechatrommer
Super Contributor
Country:
reassessing directives...
Re: Where can I get cable assemblies like this?
Reply #1 on:
March 10, 2020, 05:33:37 pm »
https://www.ebay.com/itm/40PCS-Dupont-10CM-Male-To-Female-Jumper-Wire-Ribbon-Cable-for-Arduino-MF/172278063376?hash=item281c92a110:g:ty0AAOSwD8Bc7Ipp
https://www.ebay.com/itm/To-Female-10cm-Female-To-Female-Arduino-Dupont-Line-Jumper-Wire-Ribbon-Cable/283796218232?var=585218672142&hash=item421392a178:m:mStCm9CEy3l7GNNa5_1zfeg
Logged
rea5245
Country:
Reply #2 on:
March 10, 2020, 05:41:18 pm »
Thanks, but I'm looking for a single rectangular connector on one end, not separate individual connectors.
- Bob
Logged
SoundTech-LG
Country:
Reply #3 on:
March 10, 2020, 06:27:37 pm »
In a pinch, you can use the individual connectors, arranging them how you want, attached to a header, and then glue them altogther. Hot melt glue will work. we do that alot around here.
Logged
hexreader
Country:
Reply #4 on:
March 10, 2020, 06:41:29 pm »
There are many options:
Buy the ribbon with single housings, remove the unwanted single housings by lifting the plastic tab, replace with multi-way housings like these...
https://www.technobotsonline.com/cable-assembly-housings.html
Buy ready made leads like these...
https://www.technobotsonline.com/pre-crimped-wire-f-f-30cm-50-piece-rainbow-mix.html
and slot into whatever muti-way housing you choose. All combinations male/female available in different lengths.
I have linked to a UK supplier, but all major suppliers have housings. Pre-made leads are harder to find.
You can make your own leads if you can find the right crimp tool, but this is very fiddly, time consuming and unreliable if not done skilfully.
Last Edit: March 10, 2020, 06:44:55 pm by hexreader
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
