Author Topic: Where can I get these from?  (Read 1134 times)
Offline grouchobyteTopic starter
  • Country: cn
« on: July 07, 2020, 10:36:47 pm »
I have several of these jumpers and find them very useful for breadboarding and a variety of other functions. Unfortunately, i dont remember where I obtained them from and after a web search come up with nothing. Anyone have any idea what they are called and/or where I can purchase more?
« Last Edit: July 07, 2020, 10:43:27 pm by grouchobyte »
Offline Vovk_Z
  • Country: ua
Re: Where can I get these from?
« Reply #1 on: July 07, 2020, 10:37:30 pm »
Which one?
Theese ones? (add Male or MM there).
« Last Edit: July 07, 2020, 10:42:33 pm by Vovk_Z »
« Reply #2 on: July 07, 2020, 11:12:50 pm »
The following users thanked this post: grouchobyte
  • Country: cn
« Reply #3 on: July 07, 2020, 11:32:37 pm »
These might give clues for what to search for:
https://www.ebay.com/itm/Mueller-4444-A-36-2-Stackable-080-Pin-Plug-on-Both-Ends-Red-36-/351711279572
Thanks Rob! Close but still hard to find. Gonna search again with the word stackable. The pin is 1mm in diameter and 5mm in length
Bob
Offline MK14
« Last Edit: July 07, 2020, 11:59:16 pm by MK14 »
Offline RomDump
« Reply #5 on: July 08, 2020, 01:11:35 am »
https://www.pomonaelectronics.com/products/patch-cords/pin-tip-plug-patch-cord
Check Digikey etc.
BTW: I think the Yellow colour was discontinued.
https://www.ebay.com/itm/Lot-of-10-8-Pomona-P-8-Yellow-Test-Leads-w-Stackable-Pin-Tip-Plugs-20-AWG-/133013104402
« Last Edit: July 08, 2020, 01:26:22 am by RomDump »
RomDump
  • Country: cn
« Reply #7 on: July 09, 2020, 05:13:39 pm »
Apparently most of you missed one thing.... The pin is 1mm in diameter and 5mm in length
This is much harder to find.... i am ready to give up
Bob
Offline MK14
« Reply #8 on: July 09, 2020, 05:50:04 pm »
Google, won't let me find these (1mm, 5mm length plug, stackable), linkably (but I CAN get the image).
They are probably out of stock, now. (It seems to link to a very out of date advertising site).
Possibly Rapid Electronics (UK), sold them, in the past.
EDIT: Could be 2mm diameter, or even 4mm. So, forget this.
Another option (such as https://www.mouser.com/datasheet/2/516/BananaPlugs%20D7MOOCE-257160.pdf  which mentions it), is to go for "Custom Patch-cord manufacture", depending on what budget and quantities you want.
Their experience would probably mean they know where and how to get the right plugs, and/or they can make them up. From empty plastic shells, and the range of connector bits and pieces, they have in stock.
« Last Edit: July 09, 2020, 06:14:34 pm by MK14 »
Offline cdev
« Reply #9 on: July 10, 2020, 08:02:16 pm »
Just from looking at them they look like the kinds of patch cables used in (very) old retro synthesizers?
The following users thanked this post: MK14
Offline rdl
« Reply #10 on: July 11, 2020, 12:14:37 am »
1 mm seems pretty big for poking into a breadboard. That's about the same a 18 gauge solid core wire. Other than that, I wouldn't mind having some too.
