Author Topic: Where to buy a good vactrol ?  (Read 3004 times)
Offline Jan AudioTopic starter
« on: April 01, 2020, 04:20:52 pm »
Hi, i want a vactrol for a audio-compressor, what normal shop can you buy such a thing ?
Or where else ?
thanks
Online RandallMcRee
Re: Where to buy a good vactrol ?
« Reply #1 on: April 01, 2020, 04:30:11 pm »
If you simply google you can find specialty shops that sell NOS parts. I purchased several a few years ago...Also Ebargh but then you don't what the heck you are getting.
E.g. https://www.amplifiedparts.com/products/optocoupler-vactec-vtl5c1-vactrol-new-old-stock
Randall
« Reply #2 on: April 02, 2020, 11:34:57 am »
They are a bit to expensive for me.
Maybe with a LDR and LED with printed case somehow ?, maybe not.
Ebay 5 for 5+ dollar no good then ?, maybe i should try.
Offline rvalente
  • Country: br
« Reply #3 on: April 02, 2020, 12:26:29 pm »
I've seen some guitar pedals using a LED + LDR inside a small black tube, you could use a 8mm black pneumatic (PU tubing) is really cheap...
Offline 2N3055
  • Country: hr
« Reply #4 on: April 02, 2020, 12:35:16 pm »
In a pinch I used drinking straw, and then a black heatshrinking tube over.. Worked well enough..
Dr. Richard W. Hamming
« Reply #5 on: April 02, 2020, 12:44:19 pm »
5mm CdS cell, red 5mm diffused LED, and a 2 part layering of black low temperature heat shrink and you have them. Order 100 of the CdS cells and match yourself a few pairs using a small black project box and a red LED one side and a pair the other side, and you can make a stereo set with this as well.
The following users thanked this post: Jan Audio
Offline rvalente
  • Country: br
« Reply #6 on: April 02, 2020, 01:01:43 pm »
Just out of curiosity, why RED led? Does the LDRs have different responses in wavelength?
Offline 2N3055
  • Country: hr
« Reply #7 on: April 02, 2020, 01:14:16 pm »
They do..
Farnell seems ho have some..
https://export.farnell.com/advanced-photonix/nsl-32/optocoupler-2kv-resistive-o-p/dp/3168773?st=ldr
Online RandallMcRee
« Reply #8 on: April 02, 2020, 03:43:17 pm »
They do..
Good find. The OP asked for a Vactrol which has a specific Iv/Rx curve, although its pretty loose if I remember correctly. Buying an NSL32 (its the only one actually manufactured these days unless you pop over to an H11F1M) gives slightly different characteristics. But if you are being cheap (e.g. trying to save money) just realize that making one yourself with a well-defined characteristic will be *really* tough.
Good luck.
« Reply #9 on: April 02, 2020, 03:47:14 pm »
I have 3D printer, only no black filament.
Way to expensive, they have LDR at tayda $0.24.
Offline SilverSolder
« Reply #10 on: April 02, 2020, 09:07:27 pm »
The following users thanked this post: RandallMcRee
« Reply #11 on: April 03, 2020, 03:57:31 pm »
a $50.00 minimum order
Can not buy 20, only 5.
« Reply #12 on: April 03, 2020, 04:38:57 pm »
Each pack has 10 each?  so you'd get 50 in total
There is a minimum order total of $10.00  when I look.  Maybe it is different for international?
Even spending $50 is good, don't forget we have to boost the economy in the crisis!
Offline schmitt trigger
  • Country: mx
« Reply #13 on: April 03, 2020, 04:58:08 pm »
I was under the impression that CdS photocells had a wavelength response which peaked around 550nm, green.
See attached datasheet.
Offline 2N3055
  • Country: hr
« Reply #14 on: April 03, 2020, 05:23:34 pm »
That's curious. All those that I used, used to be around  650-660 nm..
Nice to know.
Offline floobydust
« Reply #15 on: April 03, 2020, 06:20:27 pm »
I recall CdS photocells are most sensitive to green, like the human eye. CdSe are red-sensitive. But there is doping involved I think for higher gain but getting slower response.
I'm not sure why Vactrol is using red LED's - perhaps they were brighter/cheaper back in the day? Some even used neon lamps. 40mA LED drive for a 5mm part seems oddly high, so they need brightness.
I would try a CdS photocell with a high efficacy pure green LED in some heatshrink tubing and do some pulse experiments. The response time made the sound of a compressor what it is, so important to try keep that if cloning vintage gear. It seems faster CdS parts have shallower slope.
The parts are still relevant. Stumbled onto Jim Williams (July 1990), "Bridge Circuits Marrying Gain and Balance", Linear Technology Application Note 43
He uses Vactec VTL5C10 or Clarex CLM410 in an ultralow (better than a JFET) distortion sine oscillator 0.0003% or 3ppm fig.48 wow. Bless his soul.
The following users thanked this post: schmitt trigger
  • Country: mx
« Reply #16 on: April 03, 2020, 06:26:18 pm »
Your comment made me research further.
I found the following datasheet. It is indeed a CdSe photocell and the sensitivity peaks at 690 nm. Definitively blood red.
See attached.
« Reply #17 on: April 04, 2020, 01:14:24 pm »
Why are those amerikan shops so racist ?
Offline 2N3055
  • Country: hr
« Reply #18 on: April 04, 2020, 01:42:54 pm »
:-// :wtf:
  • Country: mx
« Reply #19 on: April 04, 2020, 03:23:53 pm »
« Reply #20 on: April 04, 2020, 04:29:46 pm »
Americans minimum order : 10
Others : 50
  • Country: mx
« Reply #21 on: April 04, 2020, 08:19:59 pm »
Well I am in Mexico, as as you can see in the attached images, it will allow me to order in multiples of 1, 5 10 or 50. You have to change the part number's last prefix.
Could it be related to EU customs?
« Last Edit: April 04, 2020, 08:21:38 pm by schmitt trigger »
Offline Moshly
  • What's wrong with this thing
« Reply #22 on: April 04, 2020, 11:09:08 pm »
I did some test using different colours a while back, (see attached).
Looks like the modern high brightness red give the most liner response.
HB Red: 90's translucent red high brightness
R,G,B: modern water clear Chinese high brightness RGB
UV: modern water clear Chinese
Green O: 80's opaque green
Notes: Graph is LOG/LOG
HB Red:red line touches top of graph.
The following users thanked this post: edavid, rvalente, floobydust, 2N3055
« Reply #23 on: April 05, 2020, 12:37:01 pm »
No the minimum order,
customs here are from €22,- + €13,- handling fee.
I like to order the maximum of 5 packages for 12,50 nothing more.
Its ok, at least they dont geo-block like other shops.
I am going for 100 piece optoresistor from china ( 5 types ) for almost 5 dollar.
Offline floobydust
« Reply #24 on: April 05, 2020, 11:43:48 pm »
Found a bit more Vactrol data. The spectral mismatch (red vs green drive) is intentional it seems.
I'm not sure what CdS cell size has to do with anything, beyond power dissipation. Those chinese CdS cells are tiny.
I have some huge old GE CdS cells hermetically sealed glass lens and their gamma γ (which is like a thermistor Beta) spec is high. I think that's from the number of squiggles the cell has between electrodes.
